Gmt-900 Torque Specs?
  • 3 months later...
  • Replies 47
Rich just passed me the torque specs for the 2009 GMT exhaust. If anyone is interested, here they are:
Service Information
2009 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Engine | Engine Exhaust | Specifications | Document ID: 2085633
Fastener Tightening Specifications
Application
Specification
Metric
English
Catalytic Converter to Exhaust Manifold Nut (4.3L, 4.8L, 5.3L, 6.0L, 6.2L)
50 N·m
37 lb ft
Catalytic Converter to Muffler Nut (4.3L, 4.8L, 5.3L, 6.0L, 6.2L)
45 N·m
33 lb ft
Exhaust Manifold Bolts (4.8L, 5.3L, 6.0L, 6.2L)
First Pass
15 N·m
11 lb ft
Final Pass
20 N·m
18 lb ft
Exhaust Manifold Bolt/Stud (4.3L)
30 N·m
22 lb ft
Exhaust Manifold Heat Shield Bolt (4.3L, 4.8L, 5.3L, 6.0L, 6.2L)
9 N·m
80 lb in
Exhaust Manifold Pipe to Exhaust Manifold Nut (6.0L)
50 N·m
37 lb ft
Exhaust Muffler Clamp (6.0L)
47 N·m
35 lb ft
Exhaust Muffler to Exhaust Manifold Pipe Nut (6.0L)
45 N·m
33 lb ft
Exhaust Pipe Hanger Bracket Bolt (6.0L, 6.6L)
25 N·m
18 lb ft
Heated Oxygen Sensor (HO2S) (4.3L, 4.8L, 5.3L, 6.0L, 6.2L)
42 N·m
31 lb ft
Muffler to Catalytic Converter Nut (Two Bolt Flange)
45 N·m
33 lb ft
Muffler to Catalytic Converter Nut (Norma Clamp)
28 N·m
21 lb ft
© 2010 General Motors. All rights reserved.
  • 4 weeks later...
Heres some rear axle torque specs as well....
2008 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Driveline/Axle | Rear Drive Axle | Specifications | Document ID: 1613123
Application
Specification
Metric
English
Axle Flange Bolt (10.5 Inch Axle)
156 N·m
115 lb ft
Axle Flange Bolt (11.5 Inch Axle)
185 N·m
136 lb ft
Bearing Cap Bolt (8.6 Inch Axle)
75 N·m
55 lb ft
Bearing Cap Bolt (9.5/9.5 Inch LD Axles)
85 N·m
63 lb ft
Bearing Cap Bolt (10.5 Inch Axle)
185 N·m
136 lb ft
Bearing Cap Bolt (11.5 Inch Axle)
207 N·m
153 lb ft
Brake Backing Plate Bolt
135 N·m
100 lb ft
Brake Hose Bracket Bolt
22 N·m
16 lb ft
Brake Pipe Bracket to Rear Axle Bolt
22 N·m
16 lb ft
Brake Pipe Bracket to Rear Axle Nut
13 N·m
115 lb in
Brake Pipe Junction Block Bolt
22 N·m
16 lb ft
Differential Bearing Adjuster Nut Lock Bolt (9.5/9.5 Inch LD Axles)
26 N·m
19 lb ft
Differential Bearing Adjuster Nut Lock Bolt (10.5 Inch Axle)
27 N·m
20 lb ft
Differential Bearing Adjuster Nut Lock Bolt (11.5 Inch Axle)
27 N·m
20 lb ft
Fill Plug
33 N·m
24 lb ft
Flex Hose Bracket Bolt
12 N·m
106 lb in
Pinion Gear Bearing Retainer Bolt (10.5 Inch Axle)
88 N·m
65 lb ft
Pinion Shaft Lock Bolt (8.6 Inch Axle)
36 N·m
27 lb ft
Pinion Shaft Lock Bolt (9.5/9.5 Inch LD Axles)
50 N·m
37 lb ft
Propeller Shaft Yoke Retainer Bolt
25 N·m
18 lb ft
Rear Axle Housing Cover Bolt
40 N·m
30 lb ft
Ring Gear Bolt (8.6 Inch Axle)
120 N·m
89 lb ft
Ring Gear Bolt (9.5/9.5 Inch LD Axle)
140 N·m
103 lb ft
Ring Gear Bolt (10.5 Inch Axle)
165 N·m
122 lb ft
Ring Gear Bolt ( 11.5 Inch Axle)
237 N·m
175 lb ft
Shock Absorber Nut - Lower
95 N·m
70 lb ft
Stabilizer Shaft Link Bolt
95 N·m
70 lb ft
Stabilizer Shaft U-bolt Nut
32 N·m
24 lb ft
U-bolt Nut
72 N·m
53 lb ft
U-bolt Nut (25/35 Series)
150 N·m
110 lb ft
Wheel Hub Nut (10.5/11.5 Inch Axles)
70 N·m
52 lb ft
I'd be carfull to not over torque bolts. They can shear over time. I know from experience :thumbs: . But i'm sure your aware, just my two sense.
Wow, the body mounting bolts are only 44 ft-lb? I guess i'm good with the 85 I've been going to :D (it probably changes due to the longer bolts of a body lift... BDS claims 90 and PA claims 70 in their instructions)
  • 4 weeks later...
What about the torque settings for the transmission pan bolts? This would be for a 4L60E, shallow and deep pan. The shallow pan is on an 06 Envoy 4x4 and the deep pan is on an 08 GMT-900 4x4. I would assume they would be the same.
Its the same for both.....Tighten the oil pan to transmission case bolts alternately and evenly to 11 N·m (97 lb in)
How about rear seat bolts on a GMT-900 Crew Cab?
Application
Specification
Metric
English
Front Seat Adjuster Outer Finish Cover Screw
2 N·m
18 lb in
Front Seat Armrest Screw
3 N·m
27 lb in
Front Seat Back Frame Bolt
9 N·m
80 lb in
Front Seat Bolt
90 N·m
66 lb ft
Front Seat Cushion Frame Bolt
9 N·m
80 lb in
Front Seat Cushion Frame Nut
9 N·m
80 lb in
Front Seat Nut
55 N·m
41 lb ft
Rear Seat Armrest Bolt
9 N·m
80 lb in
Rear Seat Assembly Nut
50 N·m
37 lb ft
Rear Seat Back Frame Bolt
30 N·m
22 lb ft
Rear Seat Back Tether Bolt
9 N·m
80 lb in
Rear Seat Belt Anchor Nut
50 N·m
37 lb ft
Rear Seat Cushion Frame Bolt
30 N·m
22 lb ft
Rear Seat Recliner Bolt
9 N·m
80 lb in
Rear Seat Recliner Inner Finish Cover Screw
2 N·m
18 lb in
Rear Seat Recliner Outer Finish Cover Bolt
2 N·m
18 lb in
Rear Seat Recliner Outer Finish Cover Screw
2 N·m
18 lb in
Rear Seat Riser Bolt
9 N·m
80 lb in
Seat Cushion Side Outer Cover Screw
2 N·m
18 lb in
Did I miss which post has torque specs for the front brake components on a 2 wheel drive 2008 Suburban / Silverado? I assume they would be the same.
Application
Specification
Metric
English
Brake Caliper Bleeder Screw
12 N·m
106 lb in
Brake Caliper Bracket Mounting Bolt, Front (1500 Series)
200 N·m
148 lb ft
Brake Caliper Bracket Mounting Bolt, Front (2500 Series)
300 N·m
221 lb ft
Brake Caliper Bracket Mounting Bolt, Rear (1500 Series)
165 N·m
122 lb ft
Brake Caliper Bracket Mounting Bolt, Rear (2500 Series)
200 N·m
148 lb ft
Brake Caliper Guide Pin Bolt, Front (1500 Series)
100 N·m
74 lb ft
Brake Caliper Guide Pin Bolt, Front (2500 Series)
108 N·m
80 lb ft
Brake Caliper Guide Pin Bolt, Rear (1500 Series)
38 N·m
28 lb ft
Brake Caliper Guide Pin Bolt, Rear (2500 Series)
108 N·m
80 lb ft
Brake Disc Retaining Screw (1500 Series)
12 N·m
106 lb in
Brake Hose to Caliper Bolt (1500 Series)
40 N·m
30 lb ft
Brake Hose to Caliper Bolt (2500 Series)
45 N·m
33 lb ft
What is the torque setting for the spark plugs? I thought I saw somewhere that it was 11 ft-lbs. I have the aluminum block if that matters.
Your correct...11 ft.lbs.
I know anyone who works for GM might knock me for this, but I've always ordered a haynes manual for any vehicle I own, they give you most of the torques you will ever need.
But then again this is coming from someone who is a millwright by trade that works on vehicles at work and on his own time.
