- 2
Stumble, Hesitation, Stalling At Low Rpm
Recently Browsing 0 members
247.7k
Total Topics2.6m
Who's Online 1 Member, 0 Anonymous, 763 Guests (See full list)
Question
nastyZ71
first the basics.
2000 GM sierra, 5.3 4x4 etc
I have a problem that is driving me nuts trying to figure out.
at low rpm (truck in gear and moving) the truck hesitates, sometimes almost stalling out.
I have started with the fuel system doing a pressure test and found the pressure regulator was bad
so that was changed out. now the fuel pressure is spot on according to the manual.
then figured I would do a complete tune up, new plugs and wires all amking no difference at all.
have remaoved the IAC and cleaned it, the throttle opening was also cleaned at the same time.
I did a slow speed drive around the yard with my pressure gauge hooked up to see if I was loosing fuel
pressure when the stalling occours but the pressure does not change at all.
I am at a bit of a loss here as it only happens at lower rpm with the truck moving, it idles perfect with
no DTC's showing and out on the road when you put your foot into it is takes off just like it should.
at WOT there is not stumble or lack of power.
any suggestions where I should be looking next?
0 answers to this question
