performance chip
If it is a pre-96 truck, the chip can be swapped, after that, it needs a programmer to be connected to make changes. I have a jet chip, and yes, it was one of the mods that made more of a difference than most of the others. Jet has stage 1 (for stock vehicles) stage 2 for ones with a free-er flowing exhaust and cooler thermostat, and also one with a shift improver, which is a stage 2 that increases the line pressure in the transmission electronically. I got the stage 2. I would have gotten the shift one, but already had a shift kit. Takes about 15 minutes to put one in. It actually takes longer to get the computer out than to put the chip in.
thanks...I guess I should have said that I have a 2001 Silverado LT, K&N FIPK, dual exhaust and 285's BF Goodrich's.  I looked on the internet at the JET programmer and the hypertech, but was wondering how well they worked.  Thanks for the reply. :)
I have the hypertech on an '02 Avalanche.  I like it, it allows you to touch several settings, tire size, shift points, etc.  I have a 160 thermostat on the way, that is supposed to make an additional difference when you tell the reprogrammer to use the program tailored for 160.
'02 Avalanche
FIPK2
GMAF
Gibson Catback
HPP3
MB-)
