2500 Springs
Roofer
I put 2500 Hd (1997) 8600 GVWR springs on a 1990 1500 4x4,they fit right on,raised the rear about 2",and they dont ride much worse,iot doesnt sag with the trailer now or wallow around so much.The 1500 springs were 4 leaves,the 2500 's were 6.The new style springs you can probably get the ones off the 8600 2500,they should go right on ,the onlky thing you might need is longer U-bolts.I think the 2500 rides just as good as the 1500 Silverado
  • 1 month later...
I put 2500lb over load leaf springs on my K1500 - Z-71. I got them from Dick Cepek. You maintain the factory ride until you put a heavy load in the back. I loaded 3000 lbs of stone and the truck only went down about 3".
Before I bought new springs, I would definitely check junkyard prices. Leaf springs are not something that go bad very often.
    247.6k
    2.6m
    dan rigdon
    dan rigdon
  • Who's Online   0 Members, 1 Anonymous, 718 Guests (See full list)
