Mike B Posted January 10, 2002 Share Posted January 10, 2002 Does anyone now where to get a headlight override for the driving lights on the old style?its a 98. Link to comment Share on other sites More sharing options...
gandolphxx Posted January 10, 2002 Share Posted January 10, 2002 Do you mean one to get all four lights on? Link to comment Share on other sites More sharing options...
Mike B Posted January 11, 2002 Share Posted January 11, 2002 I want to be able to control when the day time running lights are on,not like the factory has it that they are on all the time unless you use your parking brake. Link to comment Share on other sites More sharing options...
MountaineerTom Posted January 11, 2002 Author Share Posted January 11, 2002 Mike, I don't know of any off the top of my head for the '98 body style trucks. R&D Truck and Auto Acessories makes a kit for the new body style trucks that switch between the Auto Headlights and having manual control over them. When you have it switched to manual control, the DRL's don't come on. I can't remember, but do the '98's use the headlights for the DRL's or do they use the park lights? You could look for a fuse labeled DRL and try pulling it to see what happens. If it uses the headlights, and you pull a fuse, make sure your headlight work at night after pulling the fuse before you get out on the road. I have no idea if any of that will work, just throwing out an idea. Good luck. Link to comment Share on other sites More sharing options...
sincityZ71 Posted January 11, 2002 Share Posted January 11, 2002 If you pull your DRL fuse in the little fuse box on the drivers side of the dash your DRLs will be disabled but your headlights will still work fine. I did that on my old '96 and a few friends have done it on their '97s and '98s, so it works well and give you control without having to rig up something with the parking brake. Link to comment Share on other sites More sharing options...
Mike B Posted January 14, 2002 Share Posted January 14, 2002 Thanks,I will give that a try........ Link to comment Share on other sites More sharing options...
