T4RBoarder Posted November 6, 2008 Share Posted November 6, 2008 I just cranked my stock keys to get a little bit of lift for the front of my Tahoe and have always been told to get an alignment done soon after. I took my truck to a local tire shop in town for the alignment and twenty minutes later they called me and said it was all done. I would have thought for something that out of alignment it would have taken a lot longer? All they said was out was the toe, Since I dont know much about alignments here is the sheet they gave me...everything look ok? Link to comment Share on other sites More sharing options...
pm26 Posted November 7, 2008 Share Posted November 7, 2008 Everything looks OK, except for camber setting. It is within the spec, but usually you want the same (or as close to possible to same) number on both wheels, i.e 0.40 degrees for both wheels would be more like it. They apparently did not bother to reset it as it was pretty close anyway. Same for toe, you want the same setting on both wheels, but 0.00 and 0.04 are very close and it is practically impossible to achieve the exact same settings on both front wheels. The caster setting IS different or the two front wheels to compensate for the road crown. It is the caster setting that will cause the truck to pull to the side is adjusted incorrectly. Link to comment Share on other sites More sharing options...
T4RBoarder Posted November 7, 2008 Author Share Posted November 7, 2008 should I take it back and have them tweak it some more? Link to comment Share on other sites More sharing options...
jrrod2004 Posted November 7, 2008 Share Posted November 7, 2008 should I take it back and have them tweak it some more? nah, it looks good from your printout...unless you want to be anal about it Link to comment Share on other sites More sharing options...
pm26 Posted November 7, 2008 Share Posted November 7, 2008 Drive it for a while ans see if the front tires wear evenly. If you have uneven wear or pulling to the side, take it back. Link to comment Share on other sites More sharing options...
T4RBoarder Posted November 7, 2008 Author Share Posted November 7, 2008 sounds good! I'll keep an eye on the wear...I did notice right from the get go that it definitely tracked straighter Link to comment Share on other sites More sharing options...
95Sierra2500 Posted November 7, 2008 Share Posted November 7, 2008 See, I have a hard time trusting those computerized systems, especially since every time I get an alignment done by one it doesn't track straight and I get uneven tire wear. The guy I USUALLY go to for alignments still uses the old-school tools and gets it damn near PERFECT every time. Link to comment Share on other sites More sharing options...
