tranny flush
My 99 2500 has 42000 on it, I plan on doing some heavy towing and wonder if you guys and gals have had your 4L80E serviced and if you got the flush for the whole thing , converter, tranny and a filter or what and what would this cost at the dealer?  Also how about a frequency  on this interval. thanks in advance.
Guest Friz
I do mine at about 40,000 miles and it costs me about $75.00. It is definitely better than just a filter change.
$75 sounds about right.
You wouldn't believe the sh*t you'll see flushed out if you watch!  It's simply amazing what crud gets caught up in there.
I also flush the engine oil at around 50k.  It's simply amazing seeing what comes out.
Flushing has nothing to do with the filter other than replacing it with a fresh one before you bolt it all back together.  It's kinda hard to explain how it works but BG products is the maker.  It's essentially a power flush system.
I would hesitate to use compressed air not only can you damage something, but the air is only compressed for so far into the system.
