Forum/truck Abbreviations And Slang
Hi guys, I'm not sure if this has been done before, but iv been thinking for awile we need something like this pinned at the top of the forum. I'm asking everyone to participate. Hopefully a admin/moderater would agree with what I'm saying and pin a "final copy" of this topic at the top of this LD truck forum. The objective I'm trying to reach, is to cover all abbreviations and slag used here to elamanate " what does (insert) stand for?" and basically so new members or inexperienced people who join this forum know what the hell we are talking about. For example " I'm putting a new CAI on my NBS silvy this weekend. The OEM is garbage." I know when I first joined I was lost most of the time due to these abbreviations. So I'm asking everyone to participate due to the fact some know more then others. Feel free to edit, add, or correct any slag/abbreviations. If you got some your not sure what it means I'm sure someone will chime in and expalin.
Let the list begin.
Edited by todobled05
Miscellaneous
WHICH category would these be in...
EVO - Electronic Variable Orifice
BCM - Body Control Module
DIC - Driver Information Center
DRL - Daytime Running Lights
DRW - Dual Rear Wheel
EDC - Engine Driven Compressor
HVAC - Heating, Ventilation, Air Conditioning
OBA - On Board Air
Vehicle year/style
OOBS – Old Old Body Style - 73-87
OBS - Old Body Style - 88-98
GMT800 – New Body Style – 99-07
GMT-900 – New New Body style – 07+
CC - Crew Cab
CCLB - Crew Cab Long Bed
CCSB - Crew Cab Short Bed
CCSSB - Crew Cab Short Short Bed (5'8" bed)
ECSB – Extended Cab Short Bed
ECFS - Extended Cab Fleet Side
ECSB - Extended Cab Short Bed
ECLB - Extended Cab Long Bed
ECSS - Extended Cab Step Side
RCLB - Regular Cab Long Box
RCSB - Regular Cab Short Box
SCLB - Standard Cab Long Bed
SCSB - Standard Cab Short Bed
SCSS - Single Cab Step Side
STFS - Standard Cab Fleet Side
Drive train/Suspension/Chassis/Body
AAL - Add A Leaf
ABS – Anti-lock Brake System
ATF - Automatic Transmission Fluid
BL - Body Lift
CBD - Channel Body Drop
IFS - Independent Front Suspension
IRS - Independent Rear Suspension
ISS - Intermediate Steering Shaft
LCA – Lower Control Arms
NSBU - Neutral Safety Back Up Switch
SAS - Solid Axle Swap
SFA - Straight Front Axle
SFBD – Stock Floor Body Drop
SWB - Short Wheel Base
TBD - Traditional Body Drop
TCC - Torque Converter Clutch
TCM - Transmission Control Module
TPM - Tire Pressure Monitor
TTT Mirror - Trailer, Turn signal, Tilt Mirrors
UCA – Upper Control Arms
Engine
AFPR - Adjustable Fuel Pressure Regulator
CAI – Cold Air Intake
CFM – Cubic Feet (per) Minute
DOHC - Dual Overhead Camshafts
DTC - Diagnostic Trouble Code
ECM - Engine Control Module/Unit
ECU - See ^^^^^^^^^^^^
EFI – Electronic Fuel Injection
EGR valve – Exhaust Gas Recirculation
FICM - Fuel Injection Control Module
FSD - Fuel System Driver
HEI – High Energy Ignition
IAC valve – Idle Air Control
LSA – Lobe Separation Angle
MAF - Mass Airflow Sensor (MAS)
MAP sensor - Manifold Air Pressure
MPFI – Multi-Port Fuel Injection
OBD – On Board Diagnostics
OHV - Over Head Valve
PCM – Powertrain Control Module
PFI – Port Fuel Injection
PROM – Programmable Read-Only Memory
PCV Valve – Positive Crankcase Ventilation
RPM – Revolutions Per Minute
SEL - Service Engine Light
TBI – Throttle Body Injection
TDC – Top Dead Center
TPI – Tune Port Injection
TPS – Throttle Position Sensor
TV Cable – Throttle Valve
VE – Volumetric Efficiency
VSS - Vehicle SPeed Sensor
WOT – Wide Open Throttle
Interior
CEL - Check Engine Light
Universal
DMV - Department of Motor Vehicles
DOT - Department of Transportation
OEM – Original Equipment Manufacturer
GAWR - Gross Axle Weight Rating
GCWR - Gross Combined Weight Rating
GVW - Gross Vehicle Weight
GVWR - Gross Vehicle Weight Rating
PSI - Pounds per Square Inch
RPO code - Regular Production Option
Common (and not so common) Terms
AC - Air Conditioning
AFAIK - As Far As I Know
AKA - Also Know As
AMF - Adios Mother F**ker
ASAP - As Soon As Possible
ASL - Age Sex Location
AWOL - Away Without Leave
BAMF - Bad A$$ Mother F**ker
BDFB - Balls Deep From Behind
BOHICA - Bend Over, Here It Comes Again
BRB - Be Right Back
BTW - By The Way
BYOB - Bring Your Own Beer
CYA - Cover Your Ass
DFW - Dallas Fort Worth (its only on here because it is mentioned so many times on this site)
DIY - Do It Yourself
DYJHIW - Don't you just hate it when...
FNG - F**king New Guy
FTW – For The Win
FTMFW – For The Mutha F**king Win
FUBAR – F**ked Up Beyond All Recognition
FWB - Friends With Benefits
FWIW- For Fhat Its Worth
FYI - For Your Information
GMTA - Great Minds Think Alike
IIRC – If I Remember Correctly
IOW - In Other Words
IMO – In My Opinion
IMFO- In My F**king Opinion
IMHO- In My Honest Opinion
J/K - Just Kidding
KIA - Killed In Action
KISS - Keep it simple, stupid
LMAO- Laughing My Ass Off
LMFAO- Laughing My F**king Ass Off
LOL - Laughing Out Loud
MIA - Missing In Action
MILF - Mom I'd Like to F**k
MOS - Military Operations Specialty
NFW – No F**king Way
NSFW - Not Safe For Work
OMG – Oh My God
PHAT - Pretty Hot And Tempting
PIITB - Put It In The Butt
PITA - Pain In The A**
POS - Piece Of Sh*t
POW - Prisoner of War
ROFL - Rolling On The Floor Laughing
ROTFLMAO- Rolling On The Floor Laughing My Ass Off
RTFM - Read The F**kin' Manual
SNAFU - Situation Normal All F**ked Up
SOL - Sh*t Out of Luck
SOP - Standard Operating Procedure
SOTP - Seat of the Pants
TGIF - Thank God It's Friday
TIA- Thanks In Advance
TMI- Too Much Info
TTT - To The Top
WTF – What the F**K
WTFO – What the F**K, Over.
YDAFOC = Young Dumb And Full Of C*m
Edited by RyanbabZ71
That's one hell of a list, nice. Now, if only the noobs would use it.
It'd be nice if there were a series of steps one had to go through when registering here, sort of a gm-trucks.com training session that included this kind of information as well as other things like how to resize and post pictures, etc.
:chevy:
Miscellaneous
OBA - On Board Air
Vehicle year/style
NBS – New Body Style – 99-07
NNBS – New New Body style – 07+
CC - Crew Cab
AAL - Add A Leaf
BL - Body Lift
Engine
Interior
Universal
AKA - Also Know As
BAMF - Bad A$ Mother F**ker
BRB - Be Right Back
BTW - By The Way
FTW – For The Win
IMO – In My Opinion
J/K - Just Kidding
OMG – Oh My God
POS - Piece Of Sh*t
TMI- Too Much Info
TTT - To The Top
WTF – What the F**K
well i pictured it difrently im my head but that will do just fine.. PIN it!
Perhaps it would work better in the Newbie Intro category. You know, just in case they don't have a full-size truck.
Then add another sticky there telling them that if they make another "which exhaust or tire to buy" thread they'll be banned. :chevy:
Let the list begin.
Excellent suggestion!!, Awsome begining!
y2kz71,
I keep a folder for the forums I belong to. You are duly recorded, and saved!
One would hate to be a noob........
Edited by SKYrado03
  • 6 months later...
