Nbs Shorter Replacement Antenna
I'm really wanting to replace my NBS's antenna with a shorter (probably 21") one but can't find any that fit. The NBS has such a large antenna post that none of the standard after market antenna masts will fit. I have searched and searched but have yet to find one. Any of you boys had any better luck?
Daddy
  • 1 month later...
  • 5 months later...
B to the U to the M to the P. :thumbs:
Daddy
I know this is old but could you explain what you did on your antenna delete mod.
Thanks
Read this thread. It should explain everything.
Daddy
I found that one but it was done on an old body style. I wasn't sure if the same procedure was done on the nbs. Did you change out the cowl, and if so do you have a p/n?
Thanks
Daddy
Thanks
Daddy
Thanks
No cowl piece available that I know of but if you will read the entire thread, you'll see I posted how I did the delete, with pics.
Daddy
Daddy
I want to replace my anrenna as well with a little stubby one. So the bottom stalk is fatter than most after market stubby antennas? I'd like to find one though. I'm afraid of mine getting ripped off somewhere.
Daddy
You can always relocate it as I did. It can't be stolen that way and it looks better. It has been some time since I looked for differents masts, they may be available now.
  • 1 year later...
