5.3 street pounder
anfking6908
ok ive got a 5.3 stock in my 2000 Sierra this is wat i wanted to do... will it all work:
K&N CAI, Hooker full length headers
Lunati Bracket Master 2 cam
dv. Duration: 284°/284°
Gross Lift: .458''/.458''
RPM Range: 1500-5200
Harland Sharp Aluminum Roller Rocker Arm
Chevy LS1 & LS6
1.8 Ratio
Shaft Mount
Set - 16/pkg
Comp Cams Hi-Tech Triple Valve Springs
Seat Load: 304# @ 2.050''
Open Load: 848# @ 1.250''
Coil Bind: 1.145''
Rate(Lbs./In.): 681#
Be Cool High Performance Electric Fans
16'' Straight Blade Puller Fan
Black
2360 CFM @ 21.6 amp
will i have to worry about the valves hitting the pistons? or is that not going to be a very big factor in this build and also where can i look to get an idea on how much power i will be making before and after i do all this stuff. forgot to add im wanting to get a custom PCM tune when i get this done (thinking of Wait4Me)
You sure that cam is for an LS1?? Those are some pretty weak lift numbers anyway! Triple springs, good lord! Comp single 918's will do fine. You dont have to worry about piston-to-valve clearance at all. Not with those lift numbers. Honestly, do yourself a favor. Skip the 1.8 rockers and get a bigger cam. More beneficial in the long run. Which primary size are you looking at with the Hookers?
PS, Your gonna need a TUNE!!
    247.7k
    2.6m
    winprofx
    winprofx
  • Who's Online   3 Members, 0 Anonymous, 672 Guests (See full list)
