2500 hd not level
Quote from chevy4x4trucks, posted on Nov. 08 2001,3:32
To level it you just need to give the Torsion Bars a few turns.  I believe Shaners just did that on his HD.  If you look around in the Light Duty Forum you should see a ton of posts on it.
thanks chevy4x4trucks :thumbs:
Pouly,
I wanted to raise the front of my truck, so I started out by measuring from the frame down in several spots.  What I found out is that my truck leaned to the drivers side about 1/2".  I put 4 turns in the drivers side torsion bar and then drove the truck and parked it again and remeasured.  My truck is now level side to side.  I may put 2 more turns on each side now, but it won't be enough to to level it front to rear.  I think the reason these trucks sit so high in the rear is because of their awsome 9200# GVW.  That gives most of us the capacity to put over 1 1/2 tons in the bed, and still be well within our rated capacity.
Quote from Shaners, posted on Nov. 08 2001,5:08
That is the reason the trucks sit like this.  People seem to be forgetting what a one ton truck is designed for, which is towing, hauling, and just generally working hard.  If you have a truck sitting level when unloaded, the nose will be sky high when loaded down.  I personally don't like the idea of that happening, because it just plain looks bad and if you are running around at night it blinds oncoming traffic.  Thats just me though.
another option that you might want to try is the new t-bar keys or higher rated t-bars.  Each will run you 250 and require a front end alignment.  It's the way to go if you don't plan on lifting the truck in the future.  I plan on lifting mine and I'm going to get some 3/4 ton t-bars, simply because 35" tires put a great deal of stress on the truck.
Why would you want to level it?  If you do, sure they look nice, but they are that way for a reason, weight.  If you level it like people have done, then when you go to tow or haul a heavy load, your back end will sag unless you upgrade your rear suspension.  They are higher in the back so that when you load it up, the back end won't sag.
At least that it what I have always learned....
:stupid:
Hey Pick-up Man, its nice to see that I'm not the only one who
doesn't get the point of leveling the front of the truck when
unloaded.  Guess I just have to remember that alot of people
are buying these one ton trucks mainly as a commuter
vehicle, and an occasional tower.  Won't catch me doing it
though.
Quote from chevy4x4trucks, posted on Nov. 09 2001,07:57
Are you sure those keys work for the 2500HD and up trucks?
I thought it was a 1500 only thing.  Not sure he has much of
an option for higher rated torsion bars either, the current ones
will have to be very close to the upper end of the scale as far
as strength.
    247.7k
    2.6m
    Tybo8823
    Tybo8823
  • Who's Online   2 Members, 0 Anonymous, 892 Guests (See full list)
