So pics of my rig
Savage420
What size of a lift and tires do you have? Did you lose a good amount of power after the bigger tires? I was thinking about a moderate lift but i dont want to lose much power.. Thanks
Hi my lift is in my sig... :cheers: anyways there is a very slight decrese in power for me but then again look at the power add ons i have on my truck :cry: I think it comes down to what truck and motor you have cause if you try and run some 35"s with a little V6 you will probabley hate it :crackup: ...later :gmc:
looks bueno, are those eagle 058 or 187 alloys? those are the two im deciding between.
i like the look man, great work on it
Hi thanx...Actully i have nether. The ones i have on here are the 186 series.
Part # 1864-7887 16x8 Super Finish 8 on 170mm Acorn -5 mm 4 1/4 N/I 3420 lbs. 21 lbs.
WOW look at the load rating Works awsome for me on my HD
and heck there as light as a sack of potatos hahaha :crackup:
d**n, only off by one :crackup:
i am hoping to use my ROTC college money to buy a truck something liek yours, and do smiliar stuff, thats why i like yours so much
hey! awesome truck...it looks familiar ;)
http://www.gm-trucks.com/forums/index.php?showtopic=57834
WOW!!! Twins LOL That looks awsome man...They are identical trucks except for different mods and such :cheers: Looks like (WE) have the best trucks around here :flag:
Anyway you have to fill me in on what suspention lift you got going on there ...im in the market for a 6-8 inch suspention lift here soon any info on yours would be awsome . Is iit a Knuckle lift or bracket lift
. :gmc:
Later
Chris
Its a 6" BDS lift which according to the BDS website, should be:
http://www.bds-suspension.com/php/ProductBase.php?kri=151H
Its got replacement knuckles so pretty much everything is kept at stock angles. Ride feels great (well as great as you can expect from a 2500HD) and it handles just like it always did. I am pretty impressed with the way it came out.
My truck used to bottom out occasionally on the sandy beaches here but now it just floats over everything. Couldnt be happier.
Oh, BTW - I dont know about similar lifts available right now, but so far the best thing about BDS is this:
BDS Suspension. Use it, abuse it. That’s our motto. We created the best warranty in the industry. So simple we call it our “No Fine Print” warranty and it goes like this: “If you buy it and it breaks, we’ll replace it” That’s it and we live by it every day.
-Jim
-Jim
Well god dam there warrientie and MOTTO sounds awsome ...ill have to look into that lift more and see ...anyways are you planning on running a bit bigger tire ..mines stuffed with 35's with minior triming so im thinkin you could proly stuff 37's under there ,...looks great man
If you look close enough in the pics you'll see that i still had to do some trimming to make those 33's fit because they are so wide. They are 13.5" and the lift brings the width of the tires out even more so the trimming was necessary to make them not rub. If they were more like 12.5" wide im sure i could get 35's but i think 37's are kinda pushing it.
-Jim
