2500 tire pressure
Pouly,
My truck is empty most of the time or has less than 500 lbs in it and I'm running 55 psi all around.  Since I'm unloaded I don't want too much air in the rears so the tire doesn't crown and wear the center out...
Quote from CMNTMXR81, posted on Nov. 01 2001,11:43
If they are the Firestone's, I believe the ratings are 80psi cold!
yes mine are firestones and say 80psi on the side but this is max for when the truck is loaded to the max, for emty travel I would think they would wear the middle out this would also reduce your traction
Quote from raventai, posted on Nov. 01 2001,9:30
Agreed, I set mine to 50psi this weekend when I changed the oil.
  • 5 months later...
Welcome to the board :thumbs:
Now lets talk about tires, There is no way that you would want to inflate to 80psi cold on a 2500HD - that is way too much, your tires will look like a bagel and wear worse - 50 psi is plenty for the weight unless you are hauling a car trailer. :D
look on the inside of drivers door. It will tell you what to run your tires at. I run 55 in the front and 80 in the rear.
Oh My!
You do mean 55 in the REAR right?
Do a chalk test or make a graph, id sure hate to drive a truck with high pressures everyday.  Geez!
FYI- 33 front 23 rear :thumbs:
I recently increased mine from about 40# in all tires to 60# in the front and 50# in the rear.  Did it mainly to see if it would have any effect on my MPG on a long trip.  Could get 18.5 before at 75-80 unloaded, trying to break 20 MPG as some here have reported (only way I see it happening is if I drive 65).  No real improvement in fuel economy, but a much harsher ride.  I seldom tow anything, and when I do its usually about 1000 lbs max.  I think I will let some air out as the only difference is a noticably rougher ride.  Added bonus of running lower pressures may be wearing the crappy stock firestone tires out a little faster so I can replace with something better.  Take this with a grain of salt as I can't confirm it, but I read on another forum that GM released a TSB that told dealers to  replace the sticker inside the door with one recommending lower tire pressures if you take your truck in for service.
    247.6k
    2.6m
    the sandman
    the sandman
  • Who's Online   4 Members, 0 Anonymous, 523 Guests (See full list)
