1995 Serpentine Belt
I went to Murray's to get a replacement serpentine belt for my 1995 K1500 and they have two. I don't know which one to get. One says with AC and air pump, the other is with AC and no air pump. I have no idea of my truck has an air pump. :ughdance: How do I tell? Thanks much.
I went to Murray's to get a replacement serpentine belt for my 1995 K1500 and they have two.  I don't know which one to get.  One says with AC and air pump, the other is with AC and no air pump.  I have no idea of my truck has an air pump.  :shakehead:  How do I tell?  Thanks much.
Check to see if the "belt routing" sticker is still on the fan shroud. It should point out the position of the A.I.R. Pump pulley if your engine has one. It is usually monted on the pass. side of the enngine, under the A/C compressor.
