mf66 Posted May 29, 2006 Share Posted May 29, 2006 I have a 1998 Z71 GMC 1500. I have had intermitent starting problems. Hit the bottom of the tank and it would start flawlessly.....Suspected fuel pump..replaced w/filter. cleaned TB. Ran for the last week with no problems. This morning, No start. Left it for 10 minutes, and it started up. It definatley is fuel related but I just cant figure it because it is so random. I am starting to think it is injector related, but when started, it runs perfect?? Where is the fuel Pump relay on this baby??? Maybe its the relay?? HELP Thanks Mike F Link to comment Share on other sites More sharing options...
Worktruck Posted May 29, 2006 Share Posted May 29, 2006 When you replaced the fuel pump did you replace the wiring pigtail as well? I know on my sons S-10 we had the same problem and it turned out to be the pigtail was shot and burned up the new pump. Link to comment Share on other sites More sharing options...
mf66 Posted May 29, 2006 Author Share Posted May 29, 2006 When you replaced the fuel pump did you replace the wiring pigtail as well? I know on my sons S-10 we had the same problem and it turned out to be the pigtail was shot and burned up the new pump. <{POST_SNAPBACK}> I found the relay, and found 78ohms resistance across 2 terminals, and about 2 ohms across another. Could find no other combination which would show resistance. Re the fuel pump pigtail. I simply "plugged and played" No replacement. I can hear the fuel pump working. Could it still be the relay if the fuel pump works??? Thanks Mike Link to comment Share on other sites More sharing options...
Worktruck Posted May 29, 2006 Share Posted May 29, 2006 I'd say you need to check fuel pressure at the fuel rail to be sure it's not the pump or filter. Oh yeah have you changed the filter? Link to comment Share on other sites More sharing options...
