How do I fix this exhaust leak?
Sometimes you can just replace the donut and reinstall new bolts and springs and that will fix the problem. But if there's a burr or crooked weld on the inside of either mating surface, the new donut will leak also.
In that case, either dremel or grind the crooked mating surface to make it smooth, or remove the springs and bolt the connection together without them.
