Lift Options 2005 Chevy 1500 Crew Cab Z71
I am looking for information regarding a 3 to 4 inch lift system for my 2005 Chevy Z71 1500 Crew Cab. I want a bolt on kit that does not require cutting or welding. It will be used primarily on the street.
Any suggestions? Can a do it yourselfer install it? What size tires will I be able to run without rubbing?
I welcome all comments and suggestions.
Thanks.
Body lift, with a T-Bar crank you're looking at about maybe 450 for the lift if you do it yourself, which is possible if you have a good selection of tools (air tools help a ton) and you should be able to run a 315/75/16 with out any major rubbing.
    247.7k
    2.6m
    Tybo8823
    Tybo8823
  • Who's Online   4 Members, 0 Anonymous, 1,024 Guests (See full list)
