2001 Yukon XL autoride compressor does not work
Hi, I have a 2001 Yukon XL with autoride suspension and the autoride compressor does no longer work. I had my utility trailer with 1 cord of wood in it and the compressor never kicked in to level the truck. I never had any problems before. I checked all the fuses and they all look fine. I do hear a small _click_ near the compressor about 10 seconds after I start the truck (usually this is when the compressor would kick in) but the compressor never starts.
Any Ideas?
GuyRoch
Thanks ChevyTech007.
I will check _all_ the fuses first thing tonight. Although I can tell you that I did check under the hood for RTD 30A and STUD 40A and they look good.
I'll get back to you later tonight.
Again, thank you very much for your prompt reply, it is appreciated.
GuyRoch
ChevyTech007,
I did check all the fuses (al fine by the way) and the problem still persists. Again, I do hear a small _click_ near the compressor about 10 seconds after the truck starts. This leads me to believe the the sensors are working just fine as they seam to trigger some sort of _lets_go_baby_pump_me_up_ but nothing happens. I'm kinda of thinking that it is not the compressors per say that are the problem because both compressors stop working at the same time (unless there is only one compressor for both side - not sure).
I did hit a small deer the other day and had some repairs ($1800 of damage), all repairs were minor and involved front-end stuff like the grill and the entire front bumper had to be replaced, along with the fog lights. Could there be some sort of connection near the front that may cause my read autoride suspenssion to stop working. I doubt, but I though I should mention it just in case.
Thanks
GuyRoch
    247.7k
    2.6m
    noumanali987
    noumanali987
  • Who's Online   5 Members, 1 Anonymous, 777 Guests (See full list)
