94 Blazer
PaulQ
Ok here we go. Changed out my 94 fullsize Blazer 350 with Vortec heads and Vortec intake, in the process I put on new roller rockers, pushrods, and lifters along with a new crane cam(Duration 254/ 264, Lift .401/ .423). Also put on new headers.
Here comes the problem, I can't seem to get the timing right because at 0-6 degrees I get backfires and any hire than that I get a bad idle. I'm beginning to wonder if I'm chasing my tail and have another problem but what could cause these symptoms and not show a computer code.
I'm fairly confident I did my valves right. With the truck running I back off each one until it clatters and tighten down until it stops and went both a quarter and half turn and neither seemed to correct it.
Anyone got any ideas?
Thanks,
Paul Q.
No I sure didn't I bought a Hypertech for it but quite a few people said not to put it in until I get everything elsse straightened out. I'm beginning to wonder if I should just put it in and see what happens.
How do you flash the computer?
Thanks for your help,
Paul Q.
TBI it is, just changed the heads and intake to vortec. Also changed cam and headers and I was reading on Hypertechs page that their chips won't support any vehicles that don't run a stock setup. I'm thinking the programmer may be the way to go due to the fact that you pointed out and that is that my computer is the original.
Unless you know some tricks of the trade. Thanks for all your help.
P.S.
Also got some codes that popped up 32, 33, 42, and 54. EGR is brand new and will put the map sensor on tomorrow. I hear the fuel pump relay is cheap and fairly easy. Not sure about the 42( Distributor maybe, my magnetic trigger looked pretty bad).
Thanks again,
Paul Q.
Gotcha, I thought there seemed to be a slight disconnect there.LOL..Already emailed them and waiting for a reply. Everyone I talked to said it would be fine, and it seems to be I got it running and it sounds good real good just getting some intermitent backfires in the carb and now I'm thinking it's the EGR or MAP sensor error that's doing it. But once I get it all taken care of I would still like to get a chip or program for it.
