NatesChargedGMC Posted February 2, 2006 Share Posted February 2, 2006 when i try to take whipples programs off my truck, the charger will only pull 3 lbs of boost. is there a bypass valve or does the efi box run the blower. i'm getting custom tuning on my truck, but can't get the charger to work right with out the efi box.but the efi box is screwing up my tune , bad timeing,running to lean,to much shift retard, showing negative knock, ect. can't get any help from whipple. THANKS FOR THE HELP NATE. Link to comment Share on other sites More sharing options...
ABQFirefighter Posted February 3, 2006 Share Posted February 3, 2006 Nate, First of all, you CAN NOT run the Whipple without the Whipple electronics or a programmed PCM!!! This could have devestating consequences. When I installed mine, I have not used any of the Whipple electronics at all. I have a PCM from Wester's (only one I recommend for the Whipple tune). When I first installed it I was only getting 3 psi as well. I talked to Jeff (tech guy at Whipple, make sure you ask for him), and he said that there is a bypass valve that stays open when the Whipple electronics are not used. If you look at your charger, on the right lower part of the unit, you see a couple of valves with vacuum hose. I had to cut some hose and install some plugs to bypass this electronically controlled bypass valve. I will e-mail you a picture of this. Let me know if you need anything else. Jeff when i try to take whipples programs off my truck, the charger will only pull 3 lbsof boost. is there a bypass valve or does the efi box run the blower. i'm getting custom tuning on my truck, but can't get the charger to work right with out the efi box.but the efi box is screwing up my tune , bad timeing,running to lean,to much shift retard, showing negative knock, ect. can't get any help from whipple. THANKS FOR THE HELP NATE. <{POST_SNAPBACK}> Link to comment Share on other sites More sharing options...
linda Posted February 3, 2006 Share Posted February 3, 2006 Can you also Email me a copy of that too? I guess since i will not be running the whipple electronics either, i will need to make these changes too? I thought the bypass was vacuum/boost controlled and not electronic? Does this mean that it will always be in boost mode? Never naturally aspirated like the bypass will let it do at cruise or idle? Link to comment Share on other sites More sharing options...
ABQFirefighter Posted February 3, 2006 Share Posted February 3, 2006 It electronically controlled by the Whipple computer. If the sensor on the Whipple computer starts to read a lean condition, it will open the bypass and dump the boost. It works fine without the electronics, it just doesn't do the failsafe boost dump. You won't need this feature with the aftermarket PCM and injectors. Link to comment Share on other sites More sharing options...
