Z71 Suspension, Tires
My truck's sitting way too low for my interest. I can't stand to see the new fords pass by with more height than me, so I'd like to beef up my suspension just enough to give my truck an edge. The Z71 height is perfect for me...not too much to where I have to recalibrate and all, but just a littler higher. What's the easiest way to achieve that height from a stock light duty stance? Also, what size are the stock Z71 tires (I might run BFG 32's if this mod gives me the clearance)? Thanks in advance.
I looked around a little (very little) but found that pro comp makes a 3" lift for your truck for $600 It comes with spindles and a add a leave and shocks. You should be able to fit 285's with a small kit like this. Would have you 1" above a stock 4x4.
if you are looking to make a Z-71 i have all the parts you need i just took them off my 2005 GMC i have the shocks, tires and wheels, skid plates let me know if you are interested in the parts
i say that you need to replace the z71 2 inch block in the back with a 3 inch block, get new shocks, and get some ford keys to replace the torsion bars so you can crank higher.
2wd doesn't have torsion bars...It's got springs. :seeya:
Doesn't have 2" blocks either
    247.7k
    2.6m
    Lukasz Chmist
    Lukasz Chmist
  • Who's Online   1 Member, 0 Anonymous, 1,058 Guests (See full list)
