MillerClemsonHD Posted May 25, 2005 Share Posted May 25, 2005 This morning when I started my truck the check 4wd warning came up. drove to work, went in for work at lunch it was off. This happened 2 weeks ago, but then I just put it in park, turned it off and it was gone. No idea what is causing this. I used the 4wd a couple of times in the small snow I had in Jan but havent used it since. Any ideas on what might be causing this. As of right now Im going to take it to the dealership and get it checked out in the am. Link to comment Share on other sites More sharing options...
Shaners Posted May 25, 2005 Share Posted May 25, 2005 What year truck? Pushbutton 4wd? Some of the trucks have had problems with the buttons for the 4wd. Link to comment Share on other sites More sharing options...
MillerClemsonHD Posted May 25, 2005 Author Share Posted May 25, 2005 What year truck? Pushbutton 4wd? Some of the trucks have had problems with the buttons for the 4wd. <{POST_SNAPBACK}> 2004, and yeah it is a push button 4wd Link to comment Share on other sites More sharing options...
MillerClemsonHD Posted May 26, 2005 Author Share Posted May 26, 2005 Update There was a TSB for the 4wd. The reprogram the computer which fixes 80% of the trucks with this problem, the others have to get a new module. Hope this helps anyone else who may have this problem. Link to comment Share on other sites More sharing options...
Indy Posted May 26, 2005 Share Posted May 26, 2005 Update There was a TSB for the 4wd. The reprogram the computer which fixes 80% of the trucks with this problem, the others have to get a new module. Hope this helps anyone else who may have this problem. <{POST_SNAPBACK}> You would think GM would have figured it out by now, this has been going on since 1999. I had the same problem with my '99. and so has almost everybody else. Link to comment Share on other sites More sharing options...
