89 chevy headlight conversions
I would have to look at both set-ups then I could tell you what needed to be done, etc.  anything is possible if you are willing to work on it.
Myself I would keep the regular bulb because I have composites but I would switch to 4 bulb system if I could as I have never liked the composites light beam coverage from day one and the fact that you cannot adjust high beams seperately for the lower beams either.
That's helpful... :jester:
The lights will bolt right in. All you have to do is splice the plugs for the composite bulbs in place of the sealed beam connectors and you are good to go.
