Another Gearing Question/Survey?
There have been several discussions in the past few weeks about changing the gears, and I wanted to know if anyone has done this on a K1500 from the 3.73 to 4.10?  If so, what were the results?  I upped my tire size and am still DESPERATELY trying to make a decision here.  Basically, I want the uuuumpfff back from layin down the pedal that I had before I raised the tires.
Anyone... anyone...
Thanks in advance.
You can solve that problem with a gear swap for sure but if you aren't doing any towing,I'd still recommend the Hypertech PP3 and/or a K & N FIPK.
Even if you decide to do both of my suggested mods,it will be cheaper than a gear swap unless you buy the ring and pinion and do it yourself.
