180 Thermostat
To the experts:
  My 2001 GMC SLE temp reads just above 200 degrees when the truck reaches operating temp.  It gets even higher when I tow a small trailer or get it up on the highway at high speed.  I realize that the truck is not overheating, and I understand that GM has installed a 195 T-stat for a reason.  What benefits/detriments am I likely to see by dropping the stat to a 180?
I have always understood that 180 is optimum temp for gasoline/diesel engines.
anybody got any thought on this?
*Without going over the boiling point* for the coolant, the hotter an engine runs the more efficiently it runs.  Changing to a cooler thermostat will allow it to start cooling sooner, but won't keep it from overheating (which you said is not a problem).
BTW, these factory gauges are not very accurate and I don't give them much credit.  There's another topic in this forum entitled "Fluctuating Temp Gauge" that addresses this.
Roofer:
    Did you notice any changes in performance after you replaced your t-stat with the 180?  Did you set off any codes, lose mileage, performance loss/gain or anything?
    I would personally feel more comfortable having a little more cushion between operating temperature and boiling over.  I realize it's probably a non-issue (heck if it never boils over who cares!)  But with years of experience with Detroit Diesels and a multitude of Bowtie V-8's ....  I just like seeing 180 on the temp gauge!
Seemed to run a little stronger since I installed it. Hard to tell the little differences till they are gone. It goes well with my Hypertech Programmer. I have no idea on mileage, cuz I never really check that often. Hope this helps.
