01 2500HD 6.0l 4x4 programmer?custom tune?
Hi guys im liiking to get a programmer or a custom tune for my 2001 2500HD 4x4.I am looking for more performance and feul milage.I use it to pull a bassboat and I pull a 28ft camper about 4 times a year.Most of the time its used for traveling.What are your experiences with programmers and tuners?Kinda leaning toward westers since they are running a special.Any help would be greatly appreciated. Thanks
KEVIN............... I just ordered a Hypertech III for my 04
6.0. I am looking for mainly more mpg. and a little torque
mgt. override because I also heavy tow and snowplow !
The Hypertech can set many different timing, gear, tire,
shifting, etc. options with a simple plug in..................
I like the idea of being able to remove the tune and return
to the stock set up when warranty service is required.
Plus once the tune is unloaded into the truck you can use
the controller to read and clear codes on other GM OBD
2 vehicles.
I printed out a few spec. sheets on different tuners and
some are different from the others......................
Price too.......$329 for hypertech, $399 for Diablo, $529
for the Westers
I had the Hypertech "piggyback" box tuner for my 97 350
Chevy.
Set for the 93 octane tune and that b***h screamed !
I FEAR the unknown.....So went with Hypertech again
......geo
WILL post mpgs on both the 87 and 93 tunes as well as
seat of the pants feel !!!
Too bad the only dyno shop around charges $200 PLUS
for a session ! Me toooo cheap !!!!!!!! :chevy:
A Wester's tune for a 2001 is $495, less the 10% special is $445.50.
And when you buy your NEXT truck in the future, you get a $495 credit toward the tune for that truck, and the next, and the next!
Absolutly no need to remove a Wester's tune when you have to bring the truck to the dealers, they cannot see or detect it. If then reflash it for any reason, a new PCM is only a phone call away. I had a Hypertech before my Wester's tune, there is no comparison!!
Don't forget one of our sponsors PCMFORLESS. Link is to the right.
I love mine and from what I hear, they do the same things as Westers. Not sure on the mail order price, but for my dyno tune, it wasn't much more than the hypertech including all the dyno time!
Don't do the Hypertech - they're junk!  Go with the Wester's.
:chevy: Why do you say the hypertech is junk? i just bought one for my 2003 6.0 and im very happy with it. I can tell a noticable diference. i raised my rev limiter, changed tire size to correct speedo because i have a lift and changed the shift to firm and raised the top speed from factory setting to 128mph "big difference"
i'm not sure on mileage , i havent went a long distance yet. :wtf:
FREY...............I checked out PCM for less site......Quite the
deal for $250 bucks............
But like the Westers I have to swap the PCM....................
I like being able to change from the hot rod tune to the
"grunt" tune for towing or plowing at a moments notice !
I LIKE having that handheld scanner for the other GMs in my
fleet to read and clear codes with......................geo
I had one of those for my truck. Yes, it recalibrated the speedo, raised the speed governer. As for performance it did nothing, but make my truck ping. Don't count on any mileage gains because you won't get any. Go with the Wester's tune, you'll get more than doing the intake and exhaust.
Thanks for all of the replies.I already have a coputer at the shop to do all the obd2 diagnostics.I wish it would change values LOL.I am leaning toward Westers or tunes for less now.I* need to get ahold of both of them and tell them what Im looking for.This website has helped me tramendously. Thanks for all the help guys
what year you do try your hpertech on? because i know from 2002 -2003 there is a difference in performance. the guy at the local performance shop installs the hyper tech and he said with a cold air kit and the programmer he can guarantee 40hp
so my next purchase is definatly cold air kit! i can notice a difference because i have 35" tire and 410 gears and could barely roast'em on dirt now it tears it up through 2nd gear. and mid range is much better. i still wish i would have bought the 8.1 but i didnt plan on lifting it either. :chevy:
Freyguy, PCM4Less does *almost* what Wester's is able to do. Their tunes aren't bad at all, and I'd definitely get one of theirs before ANY handheld, but Lyndon Wester has the edge in experience. He's been at it for 20+ years. He modifies tables others don't touch. Plus his warranty blows everyone else away...
Mud, maybe you noticed a change with your handheld, and you may be pleased. Pop a Wester's in there and you'll understand :) !!! There really is no comparison.
Sonjaab, the thing with the Wester's is you don't have to change from race to grunt or anything- it's ALL always there. You will have two shift patterns, set to your liking, for things like you're describing. I actually use my tow-mode button for KILL-mode, and just tow in regular mode. Works awesome like that !!!
Y'all, you CAN'T beat a Wester's tune.
I've asked several times at quite a few places, whenever anyone wants to say their tune is better than a Wester's tune, to beat my numbers- 3mpg better and 1.2 seconds in the 1/4m. These are HUGE numbers, and I have yet to see any competitors tune even close to these gains.
Y'all... the numbers don't lie. Wester's can not be beat.
QUAD........$1000 bucks worth of mods and only 3 mpg. increase ??????
Wow..............I will take my chances for $329 and see if my current 17
mpg hiway increases by that or MORE.
Not to mention my plowing or towing mpg...........geo :)
WELL....The big brown truck arrived !
Installed the Hypertech 3 program in a few minutes.
I set it up for the 93 octane tune, raised rev. and shift points
to 5600 (top of power band).
Using 87 fuel till I run it out and try 93 results............
Wicked burnout ! Would barely lay a patch before !
Squeek em' shifting into 2nd at WOT !
Notice minor spark knock using 87 when pounding on it.
Also seems a bit doggy midrange.......I figure the 87 fuel
is the issue.
Will drive till the 87 is gone.....Then try some 93.......
HAPPY so far!........................
BTW: Used the handheld to clear a code in my buds GM car too!
:):cry::cry: .................geo
    247.7k
    2.6m
    Semyon Glinkin
    Semyon Glinkin
  • Who's Online   2 Members, 0 Anonymous, 736 Guests (See full list)
