Allison oil change which one to use ?
hi all im new to this forum and i went yesterday to my dealer and i ask them for changing the oil of my trany and they only have Dexron III oil which is the normal ATF and i ask them if they have the TranSynd they said they dont have them so is thear any other oil that i can use it other than ( TranSynd and Amosil ) and what do you think of Mobil 1 ATF oil is it good for Allison 1000 trany and what about the mobil 1 engine oil fully synth. and one more thing the outer oil trany filter when should i change it after how many miles .
P.S. : the manual said i should use the normal Dexron III oil in the Allison trany
my truck is not new i buy it used but i dont know whan was the last trany oil change and whats in the T-case ?
what all of you recommend me to use in the rear axle and the front ?
my truck is 2001 crew cab 4x4 2500HD with allison trany
The front and rear axles use a 75W-90 gear oil. For the rear GM reccomends their own synthetic gear oil which is purple and smells like grape juice. The downside is that it costs about $25 per qt.,and you'll need 4 qts. My truck is a 2001 and only reccomends the "grape juice" from GM. The newer trucks 04',05' reccomend the "grape juice" or a GL-5 rated 75W-90 gear oil. I think GM realized people weren't going to spend $25 a qt. for gear oil.
I'm changing out the front and rear diffs this week,and will be using Mobil1 75W-90 synthetic gear oil. You need four in the rear and two in the front. The M1 is about $7.99 per qt.
If you don't know the history of the truck,I'd change out all the fluids now. If you drain the tranny and replace the filter you'll need 7.5 qts of Dexron III rated ATF. Don't buy the Allison spin-on filter from GM,they charge $20-25 for the same filter an Allison dealer charges $7 for. When you change the filter,you'll see a donut shaped magnet on top of the old filter,be sure to wipe the magnet off and put it on top of the new filter.
Like I said,the T-case uses the same Dexron III rated fluid. It uses 2 qts.
Anything else? :(
Check this thread out.....has some pics that might help:
http://www.gm-trucks.com/forums/index.php?...topic=34659&hl=
As you can see, i did mine with no problem. I put Mobil 1 in my front/rear diff because I had a gift card for Pep-Boys. I'm running all AMSOIL in other places and I'll switch to that when it's time to change. I have AMSOIL 0W30 in my engine, and the ATF in the Tranny and T-Case. So far, it works great. I didn't really notice any mpg improvements that some talk about, but no big deal. I'm just happy knowing my engine will last forever now. :seeya:
There's always going to be a debate between AMSOIL and M1. You can't go wrong either way, but I decided mainly on AMSOIL.
