2005 Predator programmers - with new features!
Diablo has just released their Predator programmer for the 2005 GM trucks that are powered by the 4.8, 5.3, 6.0 and 8.1motors -
NEW DiabloSport Predator U7193 Update Release on 1-17-05
The Following Predator revision has been released: R2.00
Part #: U7193 / 2004-05 4.8L ­ 8.1L GM Trucks and H2 Hummer
Reason: U7193 Predator revision R2.00 was updated to add the following features:
• NEW Addition 2005 4.8L ­ 8.1L GM Trucks and H2 Hummer
• Modified tunes for 03-04 and modified/added adjustable parameters.
New adjustable parameters implemented:
Timing Table 2000rpm-4000rpm (+15% / -20%)
Timing Table 4000rpm-7000rpm (+15% / -20%)
Fuel Table 2000rpm-4000rpm (+/- 20%)
Fuel Table 4000rpm-7000rpm (+/- 20%)
Idle (+/- 20%)
Speed Limiters
Rev Limiters
Part and Full Throttle Shift Points
Shift Timing
WOT Shift Pressure
Part throttle Shift Pressure
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management ON/OFF adjustment
o Torque Management abuse mode time limit ON/OFF
o % torque reduction vs. RPM ON/OFF
o Up shift torque reduction (all gears) ON/OFF
Catalytic Overtemp protection Adjustment
o Disable P0430 and P0430 codes
o Adjust COT enable temperature
Multiple Misfire P0300 adjustment
o Misfire Low rev
o Misfire Low cyl
o Misfire idle cyl
EGR disable
o Enable/disable MPH, set high to disable
o Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
AIR code disable:
o Disable P-codes: 0410, 0412 and 0418
Rear 02 disable code:
o Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160
and 0161
We will have this new version in stock very soon! We will also be extending our Predator programmer sale though January 31st. This offer is for the Predator, your choice of a 160 or 180 thermostat and free overnight shipping to locations in the 48 states. Orders can be placed online or by calling 1-877-482-9763.
Correct me if I'm wrong, but I thought that the torque management reduction was only available with a Wester's or Nelsons etc. If the predator allows me to turn back the torque management(not all the way to 0) I would be severly interested. Any pros and cons for both ways would help..Thanks
The truck options do have a dual tune feature and seeing as how Diablo Sport also offers custom tuning, it doesn't suprise me that they have included the TM disable feature with their new programmers.
I'm running one on my '04 6.0 and I love the 93 octane program. It's definitely enough for what I need.
Most people don't need custom programs for these but Diablo can put one together.
Alot of people have been calling about the Duramax programmers. They are on sale for $359.99 with overnight shipping. Those units give the diesel trucks amazing horsepower gains! $360. can get you over 100hp and over a 200ft-lb torque increase. I'm currently running one in my '05 Sierra.
