Can a 4L80 be changed in place of a 4l60e??
You could probably find a transmission adapter, but then the pcm will need to be reprogrammed. It may also require a special wire adapter if one is made. More than likely it cannot be done.
Option 1
Add a shift kit would be a good option.
Option 2
Trade in truck for a 2500 HD.
If the transmission goes ithen you can have it rebuilt to higher spec parts and add a shift kit.
yes sir it can be done!!! i am doing it right now. you will need>>>
1.an adapter harness-speartech
2.6.0 flexplate-i have the part number
3.6.0 flexplate spacer
4.crossmember---either get one from a 6.0 or build one
5.will have top modify the driveshaft if ext cab
6.a program for the pcm
7.yoke
8.dipstick
9.cooling lines
there might be a few more things to. i plan on doing a full write up on it when i am through.
