New pics of 16x10 and 315s NO RUB!!!!!!
It looks as if this truck has no lift on it.  Is that correct?  Id never imagine you could fit 315s on a 4WD with no lift.  Is it possible?  Is that what this truck is?  Did you crank the bars to level it out?
Its all in the sig. I have a body lift, ford keys and blocks in the back.
:cheers:
Ive got a 6 inch suspension and I had to cut my bumper and the tires still hit a little in the back of the front wheel wells when turning on rough terrain.  Good luck with them  :thumbs:
I rubs a little offroad but not too bad. You also have to realise that with the lift your running it pushes the wheels out more then stock. So thats why you have more problems with rubbing even though you have a larger lift. Correct me if I am wrong.
Thanks,
Chris D.
  • 1 month later...
  • 2 months later...
