New Member with truck pics
what kind of lift is that and were did u get it at.
My goal was to stop getting those $50.00 tickets for bumpers being over 28" and keep the look as before so I decided to use air springs along with 6" Superlift suspension lift so if air bags failed I still have a suspension even when 4 wheeling. With air bags, 4 link (no room up front for bags because of CV axles) alone just one failure (hole in bag, hole in line, bad valve, compressor, ect.) and you go nowhere. So I just added air springs to raise the truck and loosened torsion in front and took out springs in rear to get bumper down to 28" or less and now I have 9" of adjustment.
6" Superlift Suspension Lift
3" Body Lift
Air Bags – Shockwave 9000 front, Slam Specialties Rs 72 Rear
All self made brackets and controller
Welcome. Wow, that interior has more guages than my Cessna 310. Pardon my ignorance; what are they all for?
Gauge pod on pillar with 2 0-200 psi dual needle gauge for air bags front , rear, tank
Dash Pod self made with
-Autometer-5701 Vac Boost for supercharger
-Autometer-5763 fuel pres for supercharger
-Autometer-5747 oil temp
-Autometer-5757 trans temp
-Autometer-5791 volt for 2 aux batteries in truck bed
GReddy Air Fuel gauge on steering column
Rancho Shock Adjustment Remote Control on console
Thanks guys
Did you see my red light camera avoidance system.
Made a air cylinder out of a 6” piece of ¾ npt pipe, 5/16 x 8 bolt, 2 washers, 2 ¾ end caps and some rubber, then it fastens to a cable that ran to the license plate hinges. The switch runs to an air solenoid that activates the air cylinder.
Just hit the switch and the license plate slaps down on the bumper till you let off.
Doubles as a thanks sign when someone lets you over in traffic.
