JBA Power cables 0850 vs MSD 8.5 mm Superconductor
  • 3 months later...
the 8.5mm MSD super conductors are great. I didn't put them on until nearly 120k miles, and I noticed and immediate driveability difference, I actually have a smooth idle, and the cold start actually rev's over 1k rpm when you fire up vs the stock 7mm firing up and barely moving the tach needle to 800rpm and then dropping to idle. I doubt either way has any advantage over the other, plus it's spark plug wire, and it's going on a stock motor.
After 120K miles you could have put stock wires on and noticed a difference.
I am going to do my first tune up on my used 2001 Suburban 5.3L. I came down to 2 spark plug wires manufacturers. I want to know if the JBA's or MSD versions are any different? or any of you guys have other products better than OEM?
I went with the blue JBA's and AC Platinum plugs, worked great and could not beat the price. Don't foget to put the heat shields back on your new wires.
Personally I would buy a set of stock wires and use NGK spark plugs.  I've read alot about aftermarket wires ain't all they are cracked up to be.
Actually you won't really notice any power difference with non-stock wires. I bought them because the only wires I could get where off brand or Autolite(Ford Product :fume: ) and they wanted twice as much as the JBA's.
  • 2 months later...
I have the MSD wires only because I broke two of my stock wires when trying to change my spark plugs. There is not any SOTP increase in HP I have noticed. And they are a cool red color which upgrades the look under the hood...if that matters to anyone.
