Tranny cooler lines leaking
Put the new engine/transmission in and fired it up. One of the transmission cooler lines are leaking, more specifically the bottom line from the connection at the transmission. I do not have the quick connect lines, but I cannot get a wrench on there.
Any advice for tightening it up?
Joe
I just replaced mine...you can reach them but its a pain :seeya:
If you have the heat shield on the pass.side of the tranny its easier to see what your doin if you take it off,then you should be able to reach your arm around the cross-member from behind,a stubby wrench is also helpfull.....like I said its a pain,but thats how I reached mine.
