flows for ss
Yes they do and it is going to be loud on your 6.0 engine.
If you'd like to hear a sound clip of the dual in/dual out Flow on a 6.0,click here.Keep in mind,that is a 50 series bigblock muffler on my 2500 HD with stock pipes and the Flow put in place of the stocker.You may get somewhat of a different sound but you'll get the basic idea.
ok well i looked up the 50 series and how see what your talking about. but the stock pipes on my ss are 3.5''and the biggest inlets i found were only 3'' with a 3.5'' outlet. so now my question is would that half inch diference make me lose power?
My understanding is that the stock mufflers taper down to less than 3" inside of the actual muffler so i doubt it would cause any actual restriction.
You may want to verify that info with someone who has cut open a stock muffler from an SS but I'm pretty sure it is correct.
on the ss its duel 2.75 in and duel 2.75 out Y into 3.5 tait pipe
if you go with 2.5 duel in/out will work but you will need a little
fab work to conect to stock tail pipe. take a look under at exaust
and you willsee what i mean :seeya:
BTW muffler is NOT duel out drivers side pipe is dead only
right side flows out. left side is a sealed off camber
