Ati vs Magna
Alright, I have been researching both of these superchargers, and it seems like the Pro-charger is the best bang for the buck... It has higher hp and torque levels than the magna charger, its intercooled like the magna charger and it cost alot less...
What do you guys think??
Ive seen people pushing some outragueous HP numbers with the Procharger F1. Most of the LS1 guys run centrifugal chargers. But on the other hand the Radix is a good unit. It all depends on what you are trying to accomplish with your ride and how much you want to spend. There is absolutely nothing wrong with ProCharger!!!
I think you should look into the turbo kits availible!! STS and CMotorsports have kits now. Might be a slight wait for them. But the results are quite nice!! Im including a vid of Parish8's truck from LS1Tech. He just got a CMotorsports turbo kit put on his truck and hes really happy with it. Thus far hes run an [email protected] on 13.5lbs of boost on a stock bottom end 5.3. Dynoed it at 494HP & 467TQ.
http://members.cox.net/recervid2/1143run.wmv
http://www.neufamily.org/03silveradologs/2...verturbovid.wmv
Whats the price on the kit installed? AT what rpm's does the turbo spool up?
Is it safe to run 13.5 lbs of boost on a stock bottom end? I heard 10 was the limit..
Hes running on stock bottom end. He just recently put in a 6.0.
