Where is the Fuel Pump Relay?
I think they hid it behind the glove box, behind an access panel. I think there are 3 relays there, but not sure what one is for the pump. If you find a red wire in there with a connector that's not connected to anything, give it 12v with the key off and see if the pump runs(unless you already found the pump prime connector)
