too rich,both banks
i cant pass e check because of codes,too rich both banks.dealer told me it was either regulator,injectors or crack in fuel meter body.(96 gmc sierra C.P.I.) i relaced all of it and drove it a while and it runs perfectly but the check engine light came on again with the same codes,too rich both banks.could somebody please offer any suggestions? thank you in advance!
Try checking the fuel pressure and make sure that its within specs...I would also try to replace the 2 O2 sensors B4 the converter,especially if they r the originals,
slow or clogged O2 sensors may also trigger the "too rich" codes...just a guess
I had the same problem with my 96 chevy 5.7. Kept coming back with the same rich codes on both banks. I changed all 4 O2 sensors with no change. Finally I removed and cleaned the egr valve. This seemed to fix the problem because I have yet to get the ses light back.
