Are there any problems with unbolting the two bolts that mount the shifting cable bracket to the pan. Then undo the nut that holds the shifter arm to the trans. The cable, bracket, and shifting arm now can be pushed out of the way and the pan be droped. This way you don't have to mess with the special clips on the linkage.
I would guess the shifting arm has a groove or slot to line up so it could be put back on properly but not sure. Thanks.
    247.7k
    2.6m
    Fezic
    Fezic
  • Who's Online   1 Member, 0 Anonymous, 485 Guests (See full list)
