SEVERE GEAR® 75W-85 100% Synthetic Extreme-Pressure Gear Lube Now Available
Black02Silverado
AMSOIL SEVERE GEAR® 75W-85 100% Synthetic Extreme-Pressure Gear Lube (SVL) is now available. The new viscosity is specifically engineered for maximum performance in severe-duty applications, such as towing, hauling, steep-hill driving, commercial use, plowing, racing, off-road use, rapid acceleration, frequent stop-and-go operation and high ambient temperatures.
Iron-Clad Protection
SEVERE GEAR maintains its viscosity for long-lasting protection against metal-to-metal contact. Proprietary AMSOIL additives form an iron-sulfide barrier coating on gear surfaces, providing the ultimate line of defense against wear, pitting and scoring.
Thermal Runaway
AMSOIL SEVERE GEAR helps prevent “thermal runaway” – a phenomenon caused by a lubricant’s inability to control friction and increased heat under high-stress conditions. By controlling thermal runaway, AMSOIL SEVERE GEAR 100% Synthetic EP Gear Lube helps equipment run better and last longer.
As always, use the look up-guide to see what is available for you vehicle.
https://www.amsoil.com/lookup/auto-and-light-truck/?zo=521390
You can also contact me to get a quote and take advantage of the GM-Trucks offer.
https://syntheticadvantage.com/
Edited by Black02Silverado
  • Thanks 1
