Piece mealed 3.5" level
It will Cali lean with just 1" blocks in the back.
May just level with struts up front then that one inch block will level the truck.
Lastly consider a 2" body lift for the remaining height.
56 minutes ago, Travis Crawford said:
2.0" above strut blocks
1.5" below strut blocks
2-4" lift control arms
2-4" lift diff drop
1" rear blocks
Is this a decent recipe for good suspension angles?
A proper lift kit is the only way to maintain the best working angles for a lift.
I have a 5.5" lift on mine. Rear is about 1.5" higher than the front (I despise a squat.)
3" front level (MotoFab), 1" front Bilstein shock lift, rear is a 3" block lift (Zone) and a 1.5" spring leaf insert (Zone) for towing.
Front control arms for a 3"-4" lift from MotoFab (zerts fittings are a plus).
Then a 1.5" body lift (Zone).
The Bilstein shocks were the most expensive part of the install.
  • Thanks 1
Just trying to understand, what components does a proper lift kits use that makes it better?
Appropriately sized UCAs and diff drops based on lift height should keep my angles good/decent is my understanding.
My 2018 sits 2.5-3" higher in the rear currently. That's the reason for the 1" rear block only.
Edited by Travis Crawford
Yes. If you're only doing a 1.5" or, maybe, a 2" lift for the front, the stock UCAs will work.
When I went to the 3" front lift, my installer said he wouldn't do it unless I had appropriate UCAs for the lift and added stressors.
If you're doing a true lift over 3-4", the install will, more than likely, come with a knuckle lift to raise the UCA ball joint connection location as well as appropriate UCAs for the added stressors to the suspension in addition to a diff lowering setup to compensate for the angle of the front front shaft.
