Sway Bar bushings torque specs
Duck26
On 10/27/2024 at 6:28 AM, Duck26 said:
Looking for the correct toque spec for the sway bar bushings on a 2015 Silverado 1500.
Maybe this:
The front swaybar on the Chevy Silverado 1500 consists of a series of brackets that hold it to the frame of the vehicle and a couple of endlink nuts that fasten it the the outer side of the car. To remove the swaybar you will need to jack up the front of the vehicle and remove both the endlink nuts as well as the brackets. To install the new swaybar you will need to move it back into the place as the old one and torque the endlink nuts to 17 ft-lbs and then torque the bracket bolts to 37 ft-lbs as well.
