2014 Silverado 5.3 #3 cyl dead miss at idle only.
40 minutes ago, LeBaron said:
Replying to KARNUT.  What are you talking about?🤔
Ok I’ll simplify. It has a few miles on it. Drive it. If it gets worse rebuild it.
I'm wondering how the ECM determines that there is a miss on a single cylinder?  If we knew this then it might help determine the cause of the issue.  Does it somehow determine that the coil did not fire?  Does it detect unburned gas in the exhaust?  Knowing this may help in determining the cause.  I would think that if it were a coil/wire/plug issue, then it would present itself under load, not at idle.
The truck can detect a miss fire by anomalies in the crankshaft rotation speed. Each cylinder fire introduces a pulse to the crank shaft rotation, these pulses each correspond to a cylinder known to the PCM by the firing order. A missing pulse means that cylinder didn't fire.
The PCM doesn't know why it didn't fire. Other clues OBDII codes might suggest other anomalies if they are strong enough to trigger. A lean condition might indicate lack of fuel from a failing injector or too much air from a manifold leak. A rich condition may exist from a lack of ignition of the injected fuel.
Thanks for the information.  Based upon this and other information provided, I believe the most likely cause of the idle misfire is likely a vacuum leak.  Vacuum is highest at idle, so a vacuum leak (unmetered air entering the combustion chamber) would be much less noticeable away from idle.  I'd say check for leaks around the intake manifold.
    247.6k
    2.6m
    Liftedrado2021
    Liftedrado2021
  • Who's Online   3 Members, 0 Anonymous, 497 Guests (See full list)
