parking lamps on right side of truck not working
Tried looking online and found some similar issues but heres hoping for some more info from you guys!
Ok, so the other day I remote started my truck and normally the parking lamps front and rear turn on. I noticed that they were only lit up on the left side of the truck. I start my truck to check my lights and also noticed that when I use the headlight switch on auto, my parking lamps light up in the dark (only on the one side), but if I switch the dial to parking lamps I have no lamps at all front or back. I have checked all the fuses and no issues there. I have also checked the rear light harness on the right side for connection issues and still all looks good. I took my rear right light out and no corrosion or anything on the connection to the bulbs. I know the bulbs are not the issue as the same bulbs are used for braking and signalling and that all works fine. I looked at the fuse box for lose connections, same as the BCM and couldnt find anything. I also followed the wiring harness under my truck to look for any damage or something noticeable and still nothing. I am wondering do I need a new headlight switch? (I havent pulled it out yet to check the connections at the back). Currently if I turn my headlamps on both are fine on the front and rear left side but nothing on the rear right side. I hope to figure this out but just cannot seem to find a solution. Any help would be greatly appreciated!
