new radio update recall N242435631
9 hours ago, rrmccabe said:
My update has been decent.  To comment on above post my 2024 LTZ has Play and Ignore when I get a text message.  Clicking play is hit or miss and does not always work. Not sure if one of the steering wheel buttons will activate play or not.
So several of you have talked about radio cutting out..  I have an issue which sounds like lack of signal where the speakers will mute for probably less than a second. But it does it on FM stations and also data streams like YouTube Music. Is this what you guys experiencing?  Except for KellyB which is obviously worse. Kelly have you tried doing a reset starting with he less invasive one of pressing and holding the end call button?  If that does not work try the full reset which will cause you to add your accounts, etc again.
My audio had issues pre and post update where it mutes everything for a second and comes back on regardless of the source. The only thing I could see is whenever an app from google updates it will make the amp cut out and back on but i haven't had any apps update since the new radio update was installed. I also noticed it in the past when the offline map built into the radio restarts itself and isn't running on just data. I just take it for what it is as it's not too long of the cut out period.
I'd like to get the update to see if it resolves my Android Auto issues, which have seemed to worsen over the recent months. I'll get in the truck, it'll connect and display my google maps for about 30-60 seconds, then disconnect. Cycling bluetooth on my phone and choosing myGMC as soon as it comes back on fixes it.. until the next drive cycle.
Other issues that have popped up: Sometimes I cannot get AA to connect at all, until I do a hard reset of the head unit. With increasing frequency, my cameras will not come on automatically or when pressing the button, and they will also not stop showing when I hit 10-20mph as they're supposed to. The overlays, for actions like adjusting the HVAC, are also inconsistently displayed.
I don't use my bluetooth phone much, but I don't want to introduce the crackling problem. Others have mentioned it's seemed to resolve itself over time, can anyone else share those experiences? In the IT world it's very unlikely for things to "fix" themselves unless something is changed.
Prior to receiving the update my radio would read my text messages to me, that I receive on my iPhone , then ask if I want to reply. It no longer asks if I want to reply, anyone figure out how to enable that??
On 10/25/2024 at 5:54 PM, sjgris said:
  Pretty sure the turbo not related to this update!
You underestimate  the GM infotainment teams ability to screw things up.
Today my infotainment system was stuck on "retrieving content" or something to that effect and I finally held down the end call button and reset it and it came back.
Yesterday the Next/Prev buttons on the left back of steering wheel would not work but eventually came back.
I like the refresh trucks dash/radio setup but no question its the buggiest system I have ever messed with.  I am a Microsoft network engineer and play around with amateur radio equipment as a hobby and GM takes the cake on this one. Very unreliable!
So ****ing sick of GM. Brought the truck in for this recall update. Went to pick it up... Android version 10 (supposed to be 12). Kernel last updated Aug 2023, Security patch last updated Feb 2023. So no, they didn't actually update the head unit. What did I need to do as soon as I got in this piece of ****** truck? another hard reset to get my phone to connect. What a garbage company and garbage vehicle.
Can anyone provide a screenshot/image of your Android version, kernel version and security patch version post-update showing Android version 12? I want to provide evidence of where this HU needs to be post-update. Another day wasted on a piece of garbage.
Thank you so much @NW-Shadow21 . Can you confirm that's a 1500 model? I know mine is the GMC variant, but they're basically the same. Was yours updated with the  N242435631 recall, or something else? This is great information.
Yep 1500 RST it was updated October 8th for the recall N242435631
Mine is a 2024 RST, but the build is 172 (not 175) and the Security Patch update date is something like Feb 2024. They do not all update to the exact same build for some reason, but it absolutely SHOULD be Android 12.
There have been 3 additional revisions to this bulletin, with the most recent that I could find posted here: https://static.nhtsa.gov/odi/tsbs/2024/MC-11007681-0001.pdf . I am printing this off and including it when I drop the truck off next (later today...). Not sure if competitor forum links are allowed to be shared,but there's a thread over on the ZR2 forums discussing this revision: https://www.chevyzr2.com/threads/recall-n242435631-03.2586/
Quote
REVISION: N242435631-05
This bulletin is being revised to remove the radio programming and to update the Warranty Information table. Please discard all previous copies of N242435631.
Edited by J69759623
10 minutes ago, J69759623 said:
It appears with the latest revision -05 radio programming is no longer a part of the recall.
Thank you. I found the -04 revision, and it looks like it drops the radio update as well: https://static.nhtsa.gov/odi/tsbs/2024/MC-11008247-0001.pdf
Do you have a link to the -05 version?
If I'm reading this correctly, it looks like there may have been complaints after the radio updates in earlier revisions regarding bluetooth phone calls. Perhaps they've dropped the radio/android updates in the later revisions while they attempt to get that sorted out. I'd would rather sacrifice bluetooth call quality to have a functional HU.
