- 0
Ac blows hot, cooling fan never gets to high speed
Recently Browsing 0 members
247.2k
Total Topics2.6m
Who's Online 12 Members, 1 Anonymous, 1,642 Guests (See full list)
Question
Migs1369
I have a 2015 Silverado with 110k recently I’ve had trouble with my AC not working as it should, sometimes at start up it blows hot air and eventually will blow cold air but it’s not as cold and doesn’t come out as strong as it should. I’ve already hooked up the truck to an AC Machine and did a vacuum and leak test and both are good and refilled Freon back to spec, replaced in-cab air filter, passenger blend door, checked all fuses and relays, did reset on AC system. One thing that is happening is that both radiator fans hesitate to start when AC is turned to high and both fans never blow at high speed, when engine temp sensor is unplugged the fans will spin in high speed but will eventually slow back down to initial speed.
0 answers to this question
