2007 NBS - trailer lights both flash when signal left or right
2007 NBS Silverado
- truck lights work fine
- plug into trailer, signal left or right and both trailer lights flash.
- tried diff trailer, same thing.
- Truck/trailer plug connectors are good.
- unplugged the connectors under the bed (back of 7 pin, 4 connectors at main block under bed).  Big pin at back of 7-pin was a bit corroded, sanded down, cleaned out and greased.  Same thing.
- nothing odd under there (ie. new damage that could’ve pinched wires)
Ideas?  Pull loom and check all wires for cuts/frays/corrosion?  Is there a specific ground at that rear block that I could check?
Thanks
try running a separate ground to the trailer, you could use a jumper cable to see if that cures the problem and if it does rig up something permanent. I put self drilling screws with crimp on ring terminals on my hitch and trailer with male/female spade connectors for the disconnect on my trailer after the ground wire in the plug broke
    247.5k
    2.6m
    Jonhy
    Jonhy
  • Who's Online   5 Members, 0 Anonymous, 762 Guests (See full list)
