2022 Chev 3500HD Dually rear spindle nut
Hi I'm new to the forum,
I'm replacing the rear rotors on a 2022 Silverado 3500 HD Dually and GM has changed the rear spindle nut style. Can someone help with the correct torque for these?
First Pass: 100 Y (74 lb ft)
Second Pass: Rotate the rear wheel bearing adjuster nut counter-clockwise 6 clicks.
Third Pass: Measure hub end play to verify it is within specification 0.025 – 0.250 mm (0.0009 – 0.009 in).
Fourth Pass: Adjust nut if necessary to reach end play within specification.
