Testing Critical Properties of Brake Fluids
63a74acc-58d6-c11b-d1ee-e1346171760c.jpegBrake fluids are unique among hydraulic fluids because they are considered safety-critical vehicle equipment by the National Highway Traffic Safety Administration (NHTSA). Their primary function is to transfer braking force from the pedal to the wheels while protecting brake system components. Savant Labs conducts comprehensive tests on brake fluids to ensure they maintain appropriate viscosity across various temperatures, remain compatible with different rubber materials used in brake systems, and do not damage metal components. Key tests include kinematic viscosity measurement, compatibility checks, and assessments of fluid stability under chemical and temperature stressors.
Incompressibility is another crucial property of brake fluids, as it ensures the effective transfer of force within the braking system. To prevent the formation of compressible gas pockets, brake fluids must have high boiling points and avoid air absorption. The Equilibrium Reflux Boiling Point (ERBP) tests measure the fluid's boiling point under both dry and wet conditions. Given these rigorous testing protocols, Savant Labs can build a testing package to meet your needs for a variety of applications.
Brake Fluid Classification
Brake fluids fit into classific0ae6115b-6830-57ed-77ed-feb64a754839.jpegations depending on their chemical composition, viscosity, and boiling point. The Department of Transportation specifies DOT 3, DOT 4, DOT 5, and DOT 5.1 in FMVSS 116. SAE specifications J1703, J1704, J1705, and ISO Class 3, 4, 5.1, and 6 mostly align with the DOT classifications with a few minor differences. Even though the Department of Transportation does not designate classes DOT 4+ or SUPER DOT 4, manufacturers often apply these designations to fluids meeting the additional requirements of ISO Class 6. Table 1 shows the relationship between these classifications.
Table 1. Comparison of classification specifications [1, 2, 3, 4].
The compatibility tests are almost identical across all DOT classes. Of course, because silicone fluid does not mix with water, tests for DOT 5 SBBF sometimes have different requirements. When testing to DOT 3, 4, or 5.1 specifications, the technician must mix water into the fluid. For DOT 5 SBBF, the technician must instead humidify the fluid. In some cases, such as for chemical stability and pH, there is no requirement for silicon-based fluids. Table 2 shows the tests and requirements for component compatibility in FMVSS 116.
Table 2. Component compatibility test requirements [1].
There are a few subtle differences between DOT and SAE limits for the stability and compatibility tests, so a fluid meeting the specifications for one classification may not necessarily meet the specifications for the comparable classification. Therefore, the actual test result is critical for understanding if a fluid meets both specifications. While the tests are nearly identical, SAE specifications call out test methods according to ASTM or DIN designations, and the FMVSS describes the test procedures and refers to SAE or ASTM standards only for materials, equipment, or calibration procedures.
The most significant difference between the SAE and FMVSS specifications is in testing for damage to mechanical equipment from repeated motion. The FMVSS uses a simulated brake system with referee standard braking cylinders. In contrast, the SAE specifications use an SRV tribometer, which measures friction and wear under oscillating motion.
Brake Fluid Specification Compliance
b5557577-2ead-cc4a-bc76-ef0e5f14ebc7.jpgIn the US, manufacturers and packagers must self-certify that their brake fluids meet FMVSS-116 specifications. Manufacturers must conduct adequate testing to ensure compliance with DOT classification and provide certification to packagers, who must, in turn, ensure the fluid remains uncontaminated and complies with labeling requirements [5]. Both ISO and SAE classifications follow a similar self-certification process [6]. The National Highway Traffic Safety Administration (NHTSA) enforces these standards by randomly testing products. If a sample fails the FMVSS-116 test procedure, manufacturers may be requested to recall the product, and legal action can ensue if they do not comply. Consumers can also report non-compliant products to the NHTSA for investigation [5].
Savant Labs offers brake fluid testing to the specifications of SAE J1703, SAE J1704, and FMVSS-116, providing manufacturers with confidence in their product certifications and offering spot checks for packagers. Testing is crucial as some fluids may fail to meet the required standards due to manufacturing variability or contamination. Savant Labs ensures all processes are correctly followed, and equipment is functioning properly during testing. Companies must closely monitor their brake fluids to maintain compliance and avoid costly recalls.
A complete list of brake fluid testing provided by Savant Labs is available.  Contact Savant Labs to request a quote.
[1] FMVSS 49 CFR 571.116 (10/1/2023) https://www.govinfo.gov/app/details/CFR-2023-title49-vol6/CFR-2023-title49-vol6-sec5 71-16. Accessed, May 5, 2024.
[2] SAE J1703TM MAR2024 Motor Vehicle Brake Fluid.
[3] SAE J1704 TM MAR2024 Motor Vehicle Brake Fluid Based Upon Glycols, Glycol Ethers, and the Corresponding Borates.
[4] Remmen Brakes. (2019, January 22). Brake Fluid: What you Need to Know [Part 2] – Standards. Accessed May 5, 2024. https://www.remmenbrakes.com/brake-fluid-standards/
[5] Office of Vehicle Safety Compliance, NHTSA, OVSC Mission, March 18, 2013.  https://www.nhtsa.gov/sites/nhtsa.gov/files/ovsc_mission.pdf. Accessed May 5, 2024.
[6] J. Light, SAE International, personal communication December 18, 2023
