- 0
Loss of power, decelerate with more throttle, multiple codes
Recently Browsing 0 members
247.8k
Total Topics2.6m
Who's Online 3 Members, 1 Anonymous, 889 Guests (See full list)
Question
Taylor T.
Okay, this is a long one. 2019 Silverado 2500HD, 6.0 Vortec gas engine vin G L96 motor. If it's important, 4x4 LTZ, approx 170,000 miles.
I have only had this truck for about a month, and it's given me multiple problems that were hidden.
First was an EVAP code which was repaired by Chevrolet, and required a new vent valve and a new purge canister.
Second was a rough/choppy idle that I took a guess on and managed to fix with all brand new NGK premium ruthenium spark plugs, NGK coil packs, and the premium spark plug wires. No check engine light on this one. Truck idles fine now.
EDIT---- Shortly after replacing spark plugs, I got check engine light, no coolant temp reading, and A/C went out. Figured out it was chewed up wiring and a broken connector on the coolant temp sensor. Replaced both plug and coolant temp sensor, wire loom, solder, and protective heat shield thing replaced. Fixed issue, check engine light cleared itself.
New issue is this.
Driving 500+ miles from FL to NC, pulling a trailer and cargo weighing about 5,000lbs (purely a guess). Had the truck in tow/haul mode going North to NC. Drives fine for multiple hours, and then suddenly I start to lose power in the high RPM range going up the rolling hills. It started where it would bog down (I could actually hear the truck fighting to increase RPM), drop RPM, and I would lose speed as though I was hitting the brakes. If I let off the throttle from the about 3/4 that I had it, to 1/2 position it would pick back up and increase speed (slowly, probably due to the uphill climb with a trailer).
As time went on, and in about 10 minutes, the bogging down got worse, and eventually any throttle would bog it down and slow the motor. No check engine light at this time. I pull over to just look everything over and try to figure out what it could be online to no avail. In this time, I also changed the air filter with a STP Premium filter, and check that the MAF sensor is not clogged/dirty. It appears to be brand new. I check that it is properly plugged in, there are no debris past the air filter, clean the filter box, and check (quickly) all the connections (ring clamps and such) to ensure no leaks. It was approx. 25 minutes later I decided to get back on the road.
No issues at this time, no check engine light. Truck has full power again through the entire power band. Driving through rolling hills and about 2 hours later it starts acting up again. Same as before, losing power gradually into lower and lower RPM range as time goes on. Check engine light this time. Drive to nearest parts store for code scan. Stopped after getting off expressway, and upon accelerating through the stop sign, truck sputters HARD. RPM's go from about 700 to 3000 and back about 4 times in the matter of about 4 seconds. I putter it to the parts store, codes are:
I do not know what to do, so I look online again, give up, and about 15 minutes later decide to try and keep rolling. Symptoms are completely gone, full power through RPM range again. About 1.5 hours later, I am off expressway travelling about 50mph. Check engine light turns off.
Next day, truck is now pulling empty enclosed trailer. Tow/haul off. About 3 hours into drive back south, rolling hills of SC, truck acts up again. I pull over before I lose all power. Wait 10 minutes and decide to move on. Full power through RPM range again.
Another hour and check engine light (undiagnosed still as of now).
Another hour and start losing power in high RPM again. I decide to throw it in neutral and kill the motor. Wait about 5 seconds and fire it back up, put it back in drive, full power again.
Did the rolling, neutral reset approx. 4 more times before reaching destination back in FL.
This is the only time I've taken the truck on a journey more than probably 50 miles without a break. Also haven't pulled a loaded trailer this far before. What could be causing all this? Could the previous random misfires from before new spark plugs have caused damage to the catalytic converter, causing a slow increase in manifold pressure until the back pressure starts to stall the truck, and then turning off the motor releases that pressure? I don't want to go buying hundreds in parts just for it not to solve the problem. I am also unsure if I will be able to test this repair until the next time I need to drive 500+ miles from home.
Edited by Taylor T.Added a repair that may be relevant to current issue.
2 answers to this question
