E-mail From Corsa
I E-mailed Corsa about some exhaust questions, and here is the response. Hope this helps!
RE: Performance
To: "Jim Browning Jr" <[email protected]>, <[email protected]>
CC: "Jim Schilling" <[email protected]>, "Bob Flores" <[email protected]>, "Paul Santiago" <[email protected]>, "Rick Fabian" <[email protected]>
Date:
Today 05:29:24 am
William,
I hope to address your questions individually:
Question: I was wondering if you made an exhaust system that had dual
side exits, one pipe for each side.
Answer: We do not offer a system with dual side exits for each side. We
do not feel that a Dual side exit exhaust system allows enough clearance
to the Driver side shock absorber. This could lead to premature shock
absorber failure due to heat.
We do offer several different exhaust options for your Silverado
(Passenger Side Exit; Dual-Under-Bumper with several tip options). We
also offer 2 different sound levels- TOURING & SPORT.
Question: Do we have dyno data?
Answer: We have dyno data that supports our claim of 14 HP peak gain.
The data also shows Torque gains of 6 to 20 lb-ft. throughout the RPM
range.
Question: Do GM engines need backpressure to make power & torque?
Answer: All engines need some backpressure to smoothen out the torque
and power delivery. An engine with NO backpressure may make great PEAK
power bit will usually lose power and torque lower in the RPM range.
The important thing to remember is that the factory exhaust manifold and
the catalytic converters contribute to over 60% of the overall system
backpressure.
Installing a CORSA Performance CAT-BACK (rear of the catalytic
converter) system only changes the components AFTER the factory
manifolds and converters thereby leaving enough back pressure to have a
broad torque and power curve. By reducing the cat-back backpressure (up
to 60% on the Silverado), we free up the engine to work more efficiently
(an engine is basically a pump- the more efficiently it breathes, the
more power it can make).
Installing a complete cat-back system is a lot more beneficial than
replacing the muffler only. Our straight-through design muffler and
mandrel -bent (no wrinkles or constriction in the bends) tubing minimize
the back-pressure and maximize the HP & torque gains. You also get the
only aftermarket exhaust that gives you an aggressive exhaust note when
you want it (at idle and while accelerating) and a quiet cruise. All
our exhaust tubing and hangers are manufactured using 304L Stainless
steel that will never rust (expect to replace the factory muffler and
pipes in 2-3 years depending on where you live).
Sorry about the long email but I wanted to make sure your questions were
addressed. There is a lot of misinformation out there regarding exhaust
systems, their function, and their design. Hope this helps in your
decision making process.
Regards,
Gautam.
Gautam Pathak
Director, Product Development
CORSA Performance
Tel: 440-891-0999 x122
Email: [email protected]
URL: WWW.CORSAPERF.COM
    247.7k
    2.6m
    Danm1228
    Danm1228
  • Who's Online   4 Members, 0 Anonymous, 900 Guests (See full list)
